My '94 is throwing a CEL 25. It is also running hot. I recently modded my Temp gage and haven't had it in long enough to get a baseline. I was towing a 5K lb load of wood with it yesterday when the CEL came on the first time. During this time I was watching the temp gage climb and stay above normal most of the time. It even got as high as a couple of needle widths from the bottom of the red. I got it home and checked out the codes. It was codes 12,21,24,25,and 31. I cleared the codes and let the truck cool. I checked all the obvious electrical connections and checked the operation of the VAF. I checked the coolant levels too. I read some relevent threads on here and replaced my K&N air cleaner with a stock one I had on hand. Link to thread:
https://forum.ih8mud.com/showthread.php?t=40681&highlight="pair+system"
On my next wood run the CEL stayed off for 30mins or so but the truck was still running above normal temperature towing an empty 1.5K lb trailer at freeway speeds (ambient temp ~70F). As I said I don't have experience with this temp gage but I am thinking that even towing like that the truck should not be running hot. I checked the CEL code and this time only code 25 came back. I am thinking that running hot is indicative of an engine running lean and code 25 talks about a lean condition.
I am really leaning towards the injectors as the problem. The injectors are original equipment and have 164K miles on them. This truck is a DD and my normal commute is 17Miles each way city driving.
Anything else people think I should/could check before I drop $200 on refurbished injectors?
