Injector taking a leak
Sandy Eggo
I replaced my injectors w/ a set from MAF. One was leaking (spraying fuel all over) so I took it all apart again :mad:, making note of the leaky injector and location. Everything look okay, not cockeyed or damaged o-ring/grommet, so I put it back together. I put the injector that leaked in a different location. The same injector leaked again . . . in the new location . . .
That injector's o-ring and grommet looked okay, and I took exceptional care putting it ALL back together. Any ideas? Got to take it apart again! :crybaby:
(FWIW: I used the FSM)
Just investigated a little more. I climbed on top of the engine (while running :rolleyes:) to get a good look at the leak. I really looks like the injector is leaking between the plastic and the metal part of the injector itself, not the seals. Is this possible?
I've decided not to tear it apart again tonight. Twice is enough in one day. I will dig into it tomorrow and give MAF a call.
I've seen them leak at the halves before. Did the LT4 conversion on my Vette and had one that was bad. It didn't leak cold,just when it warmed up it started sweating gas.
Was it rebuilt from MAF, or used, or?? Sounds like a bad injector and I personally would not try again and cross my fingers. A leaking device that puts out fuel under pressure is simply a fire waiting for the right moment to happen. I'm sure you don't want to hear the advice, but I'd ask MAF to overnight a replacement since you've tried twice and changed positions - exactly what they'd probably ask before agreeing to rocket one out.
DougM
... I really looks like the injector is leaking between the plastic and the metal part of the injector itself, not the seals. Is this possible?
Yes, give them a call for replacement. You would think that they would have caught it in the leak check part of the refurbish process? They are a flow matched set, may need to send out a whole set?
Okay, got it apart for the third time. This time when removing the suspect injector from the rail, the o-ring fell apart? :confused:
So either it was slightly damaged last time and I just didn't notice, or it has failed from taking it in and out a couple of times. So now I'm at a cross road: Do I replace the o-ring and hope that was the problem, or call Man-A-Fre? It really looked like the fuel was spraying out the side of it last night.
One more thing. When I took the fuel rail out and had all of the injectors pointing downward, that injector was dripping from the nozzle, the others were not.
I'd hate to have to take this apart again, but it would be nice to get it back on the road today.
I thought the same thing. Maybe it is just the o-ring?
Oh man, I so confused . . .
i had an injector on my old isuzu trooper do the same. I was lucky it didn't burn the truck down as it leaked down the block and onto the exhaust manifold.
DougM
I was MAF's "CLEANED AND CALIBRATED INJECTOR SET".
Get in contact with Man-a-fre and have them send you another set. I got their set for my 91 3F-e and had 2 dead ones. Malcolm from Man-a-Fre was very helpful. I ended up sending their set and mine from my truck to them. They took theirs back and had mine done up and sent them back to me with no additional charge. The only downside was my truck was down for a week, 2 days after I finished rebuilding the engine. :doh:
No need to contact MAF. Must have been the o-ring. Replaced it and no leaks now. Third time is a charm.
I cannot freaking believe it. I kept smelling gas and thought it was just residual fumes, until it just didn't go away. Snooped around last night, first going to the injector I originally had problems with. It was okay. But saw moisture/fuel all around the #3 injector. This now has to come apart AGAIN (#4).
I cannot understand what the problem is. I'm following the FSM and after the last round, I checked all of the other o-rings/gaskets carefully. In addition I took extreme caution putting the rail back in place. Twisted each one (per FSM) and torqued to spec.
Is there some trick or a tip some one can give a desperate fellow?
Doing this 4 times is ridiculous! :mad:
Just to clarify - if this leaking is ALL from the sealing square cross section doughnut rings then I can advise. But if it's leaking from the body somewhere, that's a serious issue only replacement will handle.
My personal feeling on this is that once a rubber doughnut has been distorted from improper installation once - it's useless. Happened to me also. They're very touchy. So I suggest you order a full set of O rings and doughnuts and that you get them from Toyota. I don't know MAF's source and certainly don't want to impune them, but many secondary sellers will claim it's from the same source as OEM when it is not. The precise fit and seal pressure in this application is very demanding.
I posted this once, but I found the best way to install these was while atop the engine on a board, with very bright lights prepositioned and a hand light as well. Then you lube the tips with gasoline once all injectors are hanging from the rail. Then you position them and then touch each one to align it as precisely as possible. Then you roll the rail around such that the rail end of each injector is going around in circles as the injector tips try to get into the doughnuts. Keeping pressure on the rail while circling is the key and they'll all pop nicely in. If you don't do this, you run the risk that one of them will catch on the injector tip's end and be distorted when you subsequently tighten the 3 long bolts down that hold the rail on. Good lighting is key to seeing what you're doing.
The dripping injector is also bad news. Upon shutdown, this injector will simply leak fuel into the cylinder and begin trashing the cylinder walls. Because when you come out of the store the truck's fuel pressure is zero, starting will be prolonged and harder each time. Sorry not a good picture to get the truck on the road, but to me it looks like you should return the injectors and start over with MAF. Calling them would be the best move.
DougM
Another bad O-ring. I guess I'm just not being as careful as I need to be.
Going to follow your technique Doug.
