Injector pump leak - timer cover o ring
Darwin
Hi everyone, my 80 Series 1hz injector pump is leaking from the o ring behind the rh timer cover.
Is it possible to rotate the pump enough to get to the bolts to replace the o ring. I'm stuck in darwin and the mechanic has quoted $800 just for labour.
Thanks
The Diesel Tech section in this forum is a better place to post your inquiry. You will get a better response. This section primarily covers US models which never had diesel options.
