Hi I'm putting new injectors in my 1985 bj70 (3b), and have run into a few of snags. It's my only vehicle, so if you could help me troubleshoot this sooner, I would really be grateful!!
First, there is a lot of crud where the nozzles sit. How do I safely clean that area out? I guess I'm worried about crud falling down into the cylinders, which couldn't be a good thing. How do people deal with this?
Second, I've removed everything except the very bottom gasket. I cannot see the thing inside the nozzle seat. How do I remove it??
Third, I removed the nozzle leakage pipe and found that there is a crack in it where it joins the frontmost injector. I'm afraid I may have caused this when I was removing it.
In any case, is this something that somebody can fix or do I have to try and source a new one? Also what are the consequences of running the cruiser with a crack in the nozzle leakage pipe?
Thank you in advance
