Initial MAF Housing observations
I finally got around to installing the MAF housing I got from Landtank so I thought I would give some initial observations. But let me remind you that I am not a mechanic and I have maybe about 1% of the knowledge that others on this board have. The housing went on a 97 LX with 96k on it. 2nd owner. Fresh tuneup about 200 miles ago with new fluids throughout, new plugs, cap/rotor, plug wires, belts.
First off lets just all agree that the workmanship is top-shelf. Great anodizings, all the holes were where they needed to be and the instructions were simple to read. Took maybe 20 minutes to put it on.
Truck runs smoother above 700rpm. When idling at 600-650 it still seems a bit rougher than I would like, also I have a heat shield or something that is rattling at that rpm so maybe that is clouding my judgement.
Driving seems a lot nicer. When people say that their trucks are happier to downshift they are right. I have never had the truck downshift when floored at 65 in the flats, it would just lug along unless on a hill or something. Now it is happy to drop a gear and rev up to 5k. Truck is way smoother up high in the rpm range, doesn't feel like it is going to explode. Seems to have a little more pep, like having the power button on and holding the gear a little longer. Others have said that it feels like 500lbs have been taken off the truck but I will give it maybe 200. Guess I will have to keep looking elsewhere to shave some weight.
Scanguage results with a grain of salt
At idle it used to read about 8-8.2 hp, now it is reading about 6-6.2. Max hp reading on the same spot on the same road in about the same temp increased from 240 hp to 278 today. Now I know that this truck isn't making anywhere near that number but the 15% change is surprising. Also before the hp number would jump up going from WOT to coasting. So if I was at WOT and then let off the gas the hp would jump from around 220 to that 240 that I recorded above. Now when I take my foot off the throttle the hp reading no longer does that, it drops almost immediately. I wonder if this is due to an increase in the response rate for the sensor, who knows.
So far, no codes and I am happy with it. I will let you guys know if I have any problems with it.
Cool,
I too installed this on my truck. At idle it does run a little rough but mine was doing that from the get go. I might swap out fuel filter and have my injectors cleaned to see if that helps. But all in all I do agree on what you said about the quality and workmanship on this product. Once you are toolin down the highway it runs smooth.
-Juan
