Ingersoll- Rand Ether Starter system?
Always on the Run
Does anyone know what this is, how it works? I have a sticker on my dash that reads this:
THIS UNIT EQUIPPED WITH INGERSOLL-RAND engine starter system
STARTING INSTRUCTIONS:
1. use ether per engine MFG recomendation
2. turn on ignition switch or return shut down lever to run posistion
3. hold start button in or turn key until engine starts
4. IMPORTANT: do not try to engage starter when engine is running
5. IMPORTANT: rebuild air supply to maximum reading before shutting down engine
Sorry, I could not figure out how to resize the pic of this sticker to download.
Roberto
Yeah I dont know if it is an air starter or not, I just went outside and looked at the starter, it has a Nippendenso starter that is mounted into a large aluminum contraption which kinda is on top of it in which it all mounts to the bellhousing, does that sound right?
Air starters require air.... do you have a on- board compressor??? besides that if was a air starter you'll know right off.. there is a distinctive difference...
a couple pics...
