We've been trying to diagnose an apparent overheating problem in my son's new 82 FJ40 and could use some help. The engine and radiator are in the 190-200 range after idling for 10 minutes (90 degree ambient air temp), but the temp guage is pegged at hot. The readings are from an infrared digital thermometer which he got after reading some posts here. It appears that the temp guage is not reading correctly-which may be good news. We just pulled it from a 77 FJ40 and installed it in the 82 as a test. The guage in the 82 was not functioning at all. Could the temp sensor in the 82 be shot? Are these interchangeable for 77 to 82? We're also getting readings in excess of 500 degrees on the catalytic converter. Anyone have experience with the cat converter operating range? Is this normal. Temps at the exhaust pipe are 400+. BTW this was a Calif registered cruiser.
Thanks for any advice.
