Infotainment rebooted at stoplight
Charleston, sC
Stopped at a stop light yesterday and my radio turned off, rebooted, put up the caution screen, then music reconnected and went back to normal. Anyone else? do you think it did an auto-update or is it on its way to death?
I've had it happen a few times, but not in awhile (knock on wood).
Not an update. A glitch. Wish I knew more.
Check if your battery cables are tightly connected. I had that happen to me on the way back from a dealer. Popped the hood and the negative cable was loose and losing contact partially on turns.
Same thing happened to me, thought it was an infotainment glitch but then it got progressively worse and figured out what it was once it wouldn’t start up. My terminals needed to be replaced.
Hmmm, my terminals are solid and clean, even keep them sprayed with terminal spray, battery 1 year old. When yours were bad, was it a corrosion issue?
It’s happened to me and others. There are posts on here about it. Not an update and not a prelude to death, just a glitch. It’s been a couple years since mine has rebooted, so not common.
