info -tranfercase e-brake
Actually not true. As long as you have the cdl engaged you should be able to use the ebrake on the tcase. Well I know so because my discovery has an ebrake on the transfer case and the rear ds is removed sitting on a hill.
Might be true on a Rover, but remember- the T/Cs on the old Landcruisers were always locked - no CDL to engage. Must be a reason they didn't like it.
thanks,what is a cdl,and any pic's of the ebrake on the discovery,my truck has portal axles and no ebrake
CDL = Center Differential Lock. Do a search on this site on CDL and read all about it. Can't help you with Rovers. If you mean full floating axles, your ebrake are small drum assemblies in your rear hubs. I suggest getting a FSM (Field Service Manual) for your year of 80. Don't get a Chiltons or the like - they are sadly lacking. As for how to get a FSM, - a search on FSM should help you. HTH
The rover uses a drum on the xfer case from teh factory. It holds well since it's a drum, but they also get gunked up with dirt and mud etc easily. I'd love an xfer case ebrake for an 80, but don;t know of one available off the shelf.
I also have a truck that has no ebrake from the PO..no hardware, shoes...just 2 lonely cables....so I feel your pain.
