Info on POR 15?
Madison, NC
I just bought a 79 40 in michigan and hauled it south, it has a fair amount of rust on the under carriage. a friend recommended por 15 so i tried a little and it seemed to do pretty good but i thought i would see if any one else had any other ideas on the subject before i sprayed the whole thing. any insight is greatly appreciated.
It likes going over rust.
It does not like smooth steel.
It will fade with exposure to sunlight.
If you don't have rust to put it on, use the "Metal Prep" stuff they sell. It's a special zinc phosphate stuff that gives the POR 15 something to adhere to. I also like to hit the steel with a coarse wire brush to give the steel texture for it to adhere to.
Bright, smooth shiny steel with no rust or Metal prep, and the POR will fall off in one huge chunk when you hit a bump.
+1
I've had problems with it not adhering. Should be fine going right over rust but I would use the Marine Clean and Metal Prep for sure on anything not rusted. (And would use the Marine Clean on anything rusty).
That's why they make the Black Chassis coat
fj40z,
If you check the build in my sig you will see step by step POR15 process I did. It's quite simple but it helps to see some pics sometimes
Adhesion issues on clean metal... That should concern you. There's a lot of choices for you at your local AUOTMOTIVE Refinish outlet (PPG, Sherwin Williams, Dupont, etc). Get some data sheets, ask questions, and compare. You will find that there are better choices than POR. Light Industrial coatings are generally high performance products from a durability standpoint. Urethanes are best by far, enamels are worst.
Adhesion issues on clean metal... That should concern you. There's a lot of choices for you at your local AUOTMOTIVE Refinish outlet (PPG, Sherwin Williams, Dupont, etc). Get some data sheets, ask questions, and compare. You will find that there are better choices than POR. Light Industrial coatings are generally high performance products from a durability standpoint. Urethanes are best by far, enamels are worst. Get a respirator and have fun.
