Info needed Toyota V-8
Blue Ash Ohio
Hello,
I'm getting all the parts and pieces together to install a Toyota V-8 in my 1962 FJ40 I have everything I need, BUT not sure on which way to go as far as Trannys.... Has anybody used Castlemains (Rod Shop) or Dellows adapters or bellhousings ?? I have a T-400 trans I could use but it would make for a long drivetrain in a 40 :eek: Anyway whats your thoughts guys.
Don
Don,
I had thought about using the LC trans and transfer. Not going to save you any room though. Something to investigate if you can put your hands on the parts........you may be able to swap the bellhousing from a 1UZ with an A340 (car - LS/SC 400?) to bolt up to a LC auto, talking about the tranny side, not the motor side of the bellhousing. Or start searching for a tranny/transfer from a 100?:)
The solenoid controlled Toyota tranny could be made full manual with some creative wiring eliminating the tranny ECU.........I think. :D
Also check out Pirate.....BJ on Roids had put a 1UZ in a comp buggy, he used a car tranny custom mated :hillbilly: to a cruiser transfer I think.
:cheers:
Hey Don
I have been looking into doing this swap for over a year now and this is the concoction I have come up with so far. Ls 400 V8 with the stock bell housing and an adapter plate to a R150F from a V6 four runner, the marlin crawlers toy box to mate the tranny to my stock transfer case. I haven't acctually started this yet, got the cruiser and tranny/ transfercase but still missing a motor and the money to buy one. Don't really know if this is going to work, it may be a tight squeeze. Just some food for thought
Sparky,
I have a R150F also that I'm waiting to hear back from Dellow to see if they have a bellhousing to mate them together...I need a center driveshaft transfer because I have a centered rear diff...Also if you find a 1UZ or 2UZ use a Toyota Marine wire harness and ECU that way you can use a non ECT trans or a manual trans with out a problem...
Don
Awsome, thanks for that hint. I never even thought about a marine aplication motor. Did the 1uz or 2uz come stock in any marine applications or is it just from people slapping em into their boats
Toy Teacher said:
Toyota had a marine division...have you ever seen a Epic ski boat? if so that is a Toyota boat with a 300hp 1UZ-FE VVT engine under the cover...
Don www.epicmarine.com
it would be nice to get your hands on the fsm or epc for the marine engine. On the epicmarine site it stated that Toyota removed all the smog/emissions equipment from the 1uz motors used in those boats.
