Wondering if anyone has found a source for 24V relays that aren't too expensive.
GG
GG
That's a good price. Correct me if I'm wrong, but 24V, 15A is more or less equivalent to a 12V, 30A... let me get my calculator out.
24V, 15A = 360 watts
12V, 30A = 360 watts
OK it's exactly the same
GG
I threw it on as an emergency measure when a $30 Bosch 24v relay failed after 3 days.
I've been waiting for it to die, but it's been working every day for a year...
obviously YMMV
So why didn't you return the Bosch one? .
Thanks BB, I just need to get my head around 24V, in essence it's the same thing as dealing with 12V. Make sure the load isn't greater than the relay can handle, it's just the load amperage will probably be a bit different. Where as I used 30A 12V relays for everything, I might be able to use 15A 24V mostly because of the efficiency of 24V. i.e. less amperage required for the same requirement.
GG
GG assuming all things are equal it will be half the amps. Hypothetically speaking a winch drawing 40 amps on 12V will draw 20 on 24V to do the same amount of work (watts).
No, what happens is the winch draws 40 amps at 24 volts, which is probably why it pulls twice as fast.
