incorrect torque settings or bad wrench??
Cairns, Far North Queensland
G'day folks
I'm putting the rocker assembly back onto the head and my non fsm shows torque setting as "larger dia. bolts and nuts" - 25ft/lbs and the smaller bolts 17ft/lbs. i have stretched the first bolt that i tried to torque to 17. So have i got the wrong settings or a buggered t/wrench?
cheers
If your having doubts about you wrench calibration at this point.... I would be concerned about more critical areas where it has been used thus far....those little bolts in question often get fatigued due to the manner the rocker assy. was removed from the head......for example, removing the larger ones first putting the brunt of load on the smaller... or removing @ a uneven rate...
Proto, Mac, and Snap-On are good choices.
