Inconsistent shudder at high speeds
There are plenty of threads of driveline vibrations, so I read many and followed recommendations -- checked U-joints, general drivetrain maintenance, etc. Nothing seemed to make a difference.
My symptoms:
Basically, I get a whole-vehicle shudder at speeds above 55mph or so. It starts light, then gets heavier over about 20-30 seconds, to a point where I feel like I should slow down below 50mph to get rid of it. It's not in the steering wheel and braking is smooth, so it's somewhere else. Now here's the kicker: it doesn't always happen. There are times that I can get to 75mph and drive for 30 minutes with no issues. Then there are times that it starts as soon as I hit 6mph. And to top it off, sometimes it will start, I'll slow down then speed back up a few minutes later, and it's gone. I'm lost on this one. Any ideas?
Have you rotated your tires?
Check your front wheel bearing preload.
Inner nut: 20-30 ft/lbs
Outer nut: 46 ft/lbs
Wheel bearings caused similar symptoms for me, in two different vehicles.
Rotating tires and checking bearing preload are two easy things to try. And I just did the front axle service about 500 miles ago, so bearings could be it...
I'll report back. Thanks!
Are you lifted?
If so, you running 3" or better w/o a DC driveshaft up front?
Proper pinion angle out back?
Is the moly grease level correct in the knuckles? If a bushing is dry, can cause a rumble strip type noise/feeling.
Are you lifted?
Not lifted.
Kevin -- grease should be good.
We have a weird 55-degree day tomorrow so I'll be tracking this down. I'll report back in the evening.
Question on this: FSM says 48in-lb/4ft-lb (after two 43ft-lb tightenings) for the inner nut. Last night, I tightened them to FSM spec as best I could without a more sensitive torque wrench. Where is the 20-30 ft-lb number from?
I'll take it out for a spin today and report back if this solved my problem. And thanks to the forum for the white plastic plug fix for the seat motor -- fixed that too!
Many guys have had trouble with the factory spec on the wheel bearings and have had better luck with the above method. I personally do
20 ft/lbs on the inner nut and 46 ft/lbs on the outer.
Is it better for the bearings to be too tight or too loose? I would think the consequence for them being too tight is increased wear on the bearings, but too loose can ruin spindles and other stuff in the area. I did mine to the "factory" spec but worry about them being too loose.
Preliminary report is good. I took it out on the freeway and it drove smoothly with no more shudders. It was only five minutes at those speeds, but it seems that the problem is gone. If more driving reveals anything different, I'll report back.
Thanks again to the suggestions here! Bearing preload seems to have been the culprit.
