In Moab. Need Help.
Durango, Crawlorado
74 fj55, 350, th400,
I can't engage my low range. Help!
My shifter won't go any further back. I can't do Hell's Revenge without low range; my RPMs are too low. My temp guage has been running at 220.
Where do I put my pry bar to find 4 low? Which lever do I pull?
If you know how to engage please email.
Josh
what transfer case? stock?
Been a while, let's see:
The hole on the right side of the case (just to the right of the 'case saver) sits the high/neutral/low shifter. The arm typically is around 3:00 IIRC, moving it to the right (back) will move it into high range, left (front) into low. put the truck on level ground, chock it, leave the tranny in neutral. physically grab it and see if it'll move, and don't force it by any means.
Never did find low range. I had fun anyway though. My case looks like the pic.
When you go to Moab make sure you have low range and an electric fan.
Lockers too..........
I'll post some pics.
Kane creek was a washed out winch fest. GOOD TIME:cool: :D .
