im wondering
i have a 2006 tundra limited double cab 4x4 i wanting to buy 20" wheels with 33s to 35s on it Im curious as to what size lift i'd need or would a leveling kit work. the rims im looking at are 20 x 10 with a -25 off set 6x139.7 bolt pattern and a 108mm hub any answers
You're going to need more than a leveling kit to fit anything that big without rubbing. Probably a 3" lift for the 33's but if you want to go 35's you'll need more than that. If you go to 35's you may want to regear also. Overdrive might become useless. And that tire/wheel setup is going to be HEAVY also. A brake upgrade would be a good idea too. Of course this is coming from someone who really doesn't get the whole big wheel thing. I can't see going beyond a 17" wheel unless you need the clearance for brakes.
This is not the forum you are looking for.
You could clear 33s with 1-2" leveling kit, just gonna have to trim the inside of the bumper in the front. No prob in the rear. But go here and search your heart out: http://www.tundrasolutions.com/
