I'm needin help....again
I'm trying to get my rear doors to latch properly. I bought the proper striker bolts and removed the wood screws and ill-fitting nuts. I don't know if the striker bolts are threaded into the body, or are too short to put a nut on. If someone has a pic or info it would help . Thanks John (I searched already)
If the bolts thread into the floor then it looks like po drilled them out.
Is it supposed to be the size of the striker? Do you think Toyota still has that part? Thanks, John
I doubt it, but maybe you'll get lucky. I'd prolly just run new countersunk screws and a little plate behind the nut. Make it work...
Edit: I just checked mine out and being that it's fiberglass there's just an aluminum plate on the uderside with holes tapped for it. Keep it simple.
Thanks guys
I found a couple nuts w nylon locks that fit trmporarily. No to get me one of those plates. Thanks again John
