I'm leaking from every orifice
PHX
Hey all, looking for some insight from those who put some serious miles (for a 40) on their 40s. I've had mine ~4 years and have put 30+k mi on it in that time (a glorious 30k). In that period of time it has developed leaks literally everywhere aside from brakes and clutch. Instead of keeping up with these leaks I have prioritized going on the next trip (and the next, and the next), and I've reached the point where I need to do something about it. Additional datapoint being that I have no knowledge of previous service relating to this.
As much as I enjoy working on rigs, I have discovered I enjoy exploring the Southwest as much or more. With that in mind, I am wondering how others have fared while putting big miles in less than ideal conditions (65mph+) on their 40s. I am happy with the idea of resealing / rebuilding everything (it's a stock 79, 2f/H42/4 speed case), particularly because I plan on sticking an H41 and Orion in for gearing. That said, I don't want to do this if I'm fighting a losing battle and will be pissing out of every oil sealing interface again 2 years from now.
Another option is to swap in something, but I like the character of the rig as it stands (hence the H41+Orion interest, I've done the modded route before). Likely candidate would be the Cummins option, but even not considering the cost factor am not stoked at the concept.
Anyone have experience with similar usage, or feedback of what service intervals on a newly mechanically restored rig looks like?
Cheers :beer:,
Chase
Please post a list of all of the leak locations. Include pics.
My recommendation is to keep it stock or as close to stock as possible.
Leaking fluids are part of the "fun" of owning a FJ40. They all leak something somewhere. Well, I guess there are some highly restored 40s that don't leak something. When we purchased Miss Scarlet a little over two years ago she was leaking at the front knuckles, rear main seal, tranny seals, pan gasket, valve cover gasket, master cylinder, and probably a couple of other places. Oh, almost forgot about several coolant leaks. I couldn't take her visiting anywhere because of the mess she made in friends' driveways. She was like a Las Vegas hooker she looked real good until you looked underneath.
We prioritized the obvious safety problem like no brakes and then did the knuckles. Next was the pan, valve, rear main seals and tranny/transfer case. After two years and thousands of dollars in repairs she still has an oil leak of a few drops per week. We put a bed pan under her and called it good.
Miss Scarlet is more of a show girl rather than a high miler. But I'm confident that we could now take her on some extended trips. Not sure our backs could take it not to mention our pocket books at 10 or so mpg she gets.
Prioritize your leaks according to safety and severity. Then address them as needed. Many may be clustered together such as rear main seals and tranny/transfer. When you drop the tranny lots of things can be fixed at once. We had to go for the pan gasket early because it leaked so bad she dripped from stem to stern.
Just keep the faith.
I know I need to rebuild the knuckles / front axle (plus throw some RCVs, aisins, and a locker in at the same time), rear pinion seal seems to be throwing stuff, tcase and tranny I've not carefully investigated due to plan to replace, and engine I am honestly overwhelmed with. I said I didn't know history in first post, but that's wrong. I failed to mention I had rear main, the oil galley/cam plugs and oil pan gasket done last year when I had some self-imposed downtime (broken collarbone, hard to shift or work on it).
Any thoughts on big contributors outside of what's been replaced on the engine side?
I hate leaks. So, my suggestion is to pull the motor and transmission and fix them right. Clean everything and put it back together again. You will be happy.
Cheers :beer:,
Chase
