Ignition Timing
Reno
A question about setting the timing on my 93. Following the instructions under hood and jumping the 2 terminials and setting the timing at 3 deg btc, I have noticed that when I go to check the timing when the terminals are not jumped it still reads the same. I quess my question is, should the rpm or timing change when the jumper is put into place it just seems there is no change either way. Engine runs fine just curious.
Thanks
With the jumper not connected, you should see the timing go up and down a little. If its not, then you have a problem. Check it again and watch to see if it varies a bit.
The jumper keeps the timing steady while you check it.
The FSM says it should jump between 2 and 13 deg with the jumper removed.
