Ignition Timing ??
My 1997 LX450 with the inline cyl. has 195,000 miles, and seems to be real sluggish in power. Runs good, but when pulling a trailer with an ATV it is just useless when I come up to a hill. Have to keep my foot to the boards.
Does the ignition timing compensate and adjust for the high mileage?? I'm wondering if the wear in the gears for the distributer drive end up leaving the ignition timing running a little LATE giving me the poor power on hills, or is this engine just undersized for this unit.
Any suggestions what to set the ignition timing at?? , or any other ideas on what to check for the poor power. I think it's rated at 212 HP which isn't a lot to begin with.
Any help is appreciated.
Ed
When is the last time you checked your timing? And did you jump the two terminals that are responsible for elevation change?
And don't worry about the gears. If they're wearing, they'll be the 1st I've ever heard of.
3FE powa!!
Mileage? No, shouldn't never need to. It compensates for the most optimum, spark for efficiency though.
NO, never seen timing gears wear.
Real motors, motors that last, have little regard for "power". :bang:
**Rant**
When will america be happy?..When motors will sling them out of the back glass when you floor'em?
Factory recommendation
or any other ideas on what to check for the poor power?
Too many to list here. Fuel filter, Air filter... PM stuff is where I'd start
Ed
Thats 212 H.P at 4,000 rpms. You don't have that power until your at that rpm. Thats called "peak", and the torque peak is at 3,200.
Its not a boat motor, thats why you need gears with almost every deviation in tire diameter.
Quite frankly it sounds like your expectations are alittle too high.
just alittle :flipoff2:......You're in the 95th percentile :lol:
am I to take it that you have a 3FE?
please enlighten us..............
Yes, I have a 3fe. Now can I play in your little club?
