Ignition timing
Reno
A question about the timing again. Timed the crusier according to service manual did the short circut via a wire and verifed my check engine light was on. Set the timing at 3 deg btc and when the short circut is removed no change in the timing what so ever? Now there seems to be a stumble at around 2000-2500 rpm 65-70 mph. Any advice on this one? Yes I have double and triple checked where the shot circut needs to go, dont have the actual sst but using a 12ga wire witch I hev read will do the same trick.
Is the 80 bone stock? if any of the exhaust has changed it might change the way it runs and seems happy. I'm sure you will get people that will disagree, but i have noticed with installing headers or more free flowing exhaust, if you advance the timing a bit(5 deg-give or take) it helps alot with the overall performance. If it is completely stock, i would still sugg. advancing the timing just alittle bit.
On my 80(96') I have a supercharger and have adjusted the timing quite a bit. Now i know it is a different beast, but all motors work the same. This is just FYI. My timing is at about 9 deg BTDC. I tried all the way to 15 deg, while experiencing awesome power, also alot of Pinging. With the supercharger and the header(forgot to mention) if the timing is set to the sugg. 3 deg, it doesn't run very well.
Yep bone stock it was set at 15 deg for quite some time (see prevoius post)by accident maybe I will try and set it at 5 deg and see what happens. I am just curious on why it is set the same when the data link is short circuted or not.
