Hey guys, long story short I have a cranking/ no start/ no spark right '94 1FZ-FE right now. I searched and found very little useful info. Also, my FSM doesn't have much detail as far as description of the ignition system. I don't wanna just follow the flow chart, I wanna understand how it works. Here's my understanding:
The igniter is inside the distributor, it gives a signal to the Engine Control Module which fires the coil ground. Correct? I have 12v+ at the coil but no pulsing ground signal. Haven't had time to check the igniter resistance before I had to leave for work today. School me on system description/ operation please. I understand the basics I just wanna know the control side. Also, does this truck have a crankshaft position sensor or does the igniter give tach signal and time the injectors correctly also? I could look myself, I know, but I have 4 minutes of lunch left and you're not busy anyway. That's why you're putzing around here, right?
