Sorry for the length . . .
Yesterday morning it was about -10 degrees and when I went to start the cruiser the key was stuck in the off position. After much cussing and going to wake the
up. I decided to give it one last shot and amazingly the key turned and everything was good.
I got to work and the key would not turn to the off position. This is nothing new, and I can usually remedy it by playing with the shifter. There was no such luck this time, so the cruiser got to sit in the parking lot unlocked all day. After work I drove home and the key went all the way to the off position.
About an hour later I went out to start the cruiser and the key wouldn't leave the off position again. No amount of sweet talking or threats seemed able to convince the key to turn and I ended up plugging a ceramic heater in and sticking it in the cab and coming inside to see if I could find anything on here.
So far I have tried every key I own, pushing the shifter forward (and every other direction). Turning the wheel back and forth (it then locked, so I tried the keep turning it trick). Depressing the shift lock. Depressing the shift lock, while turning the wheel. I even put it in neutral and rolled it back and forth a few feet, but that didn't work either.
Today I went to the dealership and got a new key cut from code (only $10, I was surprised), but it appears that the tumblers have been switched at some point in the vehicles history and that was a bust (key was nowhere close to the old one).
Right now I am thinking about calling a locksmith to see if I can get it to the 'acc' position and getting a new tumbler. Is there any other things I should be looking for?
Any help appreciated.
Thanks.
up. I decided to give it one last shot and amazingly the key turned and everything was good.I got to work and the key would not turn to the off position. This is nothing new, and I can usually remedy it by playing with the shifter. There was no such luck this time, so the cruiser got to sit in the parking lot unlocked all day. After work I drove home and the key went all the way to the off position.
Thanks.
