Ignition Relay Location
Portland, OR
Website
www.mangai-rollin.com
Hello all.
I'm trying to suss out a no start problem. My '03 100 series is having an intermittent starting problem. Sometimes she fires right up. Sometimes she doesn't. When she doesn't, there's power to all of the accessories, but there's no crank, no click, nada. Fuses look fine; the relays in the engine bay fuse box look fine. I understand there's a couple of ignition relays somewhere else in the cab; possibly behind the glovebox. I've searched through the FSM and various threads under "ignition" and "relay" and haven't found anything resembling my symptoms.
What sayeth the MUD gurus?
@aljollano - I sure hope not. The starter was replaced ~20k ago as part of the 180k maintenance.
@bigredmachine - I'm digging through an online copy of the EWD now (thanks for the suggestion), but it's really tough to follow. Electrical systems are complicated!
....so digging through the EWD, I've found a diagram locating the Ig1 No. 3 Relay (see attached pic). It seems to match the shape and size of the mounting plate that the RH (passenger side) fusebox is mounted too. Anyone have any experience getting at this relay? It looks like I just need to unplug the various plugs going to it and unbolt the plastic mounting plate.
Maybe it's the relay, but I'd certainly try a fresh battery and clean the battery contacts real good next time it happens and see if that fixes it. Also, I heard some people have problems with the fusible link near the battery. I know you think it is a relay because all the lights work, but the starter doesn't even click, but I reckon low voltage/ bad connection could also cause this. Or it could be the starter contacts.
next time it will not start open the electrical box that contains the relays under the hood... with the end of a screwdriver give a mild TAP to the tops of ALL the relays (just because i forgot which one it was) I've posted info on this before (as have others) if you do a forum search you will see it... but the TAP on the relay will usually get you going.... try removing all the relays and cleaning the connections and then coating with dielectric grease I posted how to build a $5 20amp relay to bypass this...that has been working for years in my 2001 lx470
no you would not have to unplug the fuse block, the relay should just plug into it. don't know if its available on the pdf version but in the printed ewd the first section covers how to read and use the ewd to find locations, pin numbers, connector locations and such.
Thanks for the input guys.
@marshotel - The battery is fresh (6ish months) and the contacts look good. I'll find the fusible link and take a look at it.
@ponytl - I've read through most (maybe all) of the threads on the immobilizers, EFI fuses & EFI relays. These all seem to describe a symptom of cranking, but not starting. My truck is not cranking at all.
@bigredmachine - I'd heard from a couple of diff cruiser owners that the Ig1 No 2 and No 3 relays were worth checking out if the primary fuses and relays in the engine bay weren't the problem. What leads me to believe that the Ig1 No3 relay is BEHIND the RH interior fuse box plate is the diagram above matches the plate shape and size of plate that the RH FB is mounted to but upon inspection, there's no relay there. I've also heard that it can be behind the glove box, so I'm attempting to figure it out.
All in all, I'm not real comfortable with complicated electronics, so I may have to throw in the towel and have the rig towed to the shop.
following up on this for other's future knowledge:
Had the truck towed into the shop and got dinged for the following:
1. Test starter motor and sub relay - .5 hr
2. Test control / ignition switch side of circuit - 2 hrs
3. Trace and located IGN1 #3 relay - 1 hr
4. Disassemble and remove glove box, ECU, blower motor, lower heater box, and other under-dash components. Clean and vacuumed debris from heater box and blower motor housing. - 4.5 hrs
5. Remove passenger side sub relay panel from cowl. Test intermittent relay, install new relay, and reinstall sub panel back into passenger cowl. - 1.5 hrs
TOTAL: 9.5 hrs x 105/hr + 77.75 relay = $1075.25 OTD.
The final bill was a bit of a shock bc I was told it was a minor issue that would only take a couple of hours. Lesson learned.
Just curious and eager to learn. Someone please educate me: why does it need 3 relays (instead of 1) for the ignition system?
...something I'd like to learn as well. ...and why aren't they in the engine bay?
So in the end it was an 'intermittent relay' - which is where exactly? I see two ignition and a starter relay in the fuse box under the hood. What is considered the 'main' relay and where is it -saw something about it in another thread?
I'm having the same symptoms you originally described and trying to learn myself.
Can a relay be tested with a multimeter?
Looking to rule out as much as I can and hopefully fix the issue before taking it to the shop. It's only happened twice - at least a week, probably two, apart. Trying to get ahead of whatever it is completely failing.
So any word on a solution to this problem?
When previously having the problem I went and had the battery tested and the cold cranking amps were low so I replaced it. No further problems until this week - first event was a day after having my oil changed when leaving work (noticed the headlights were on while up on the rack - not sure if that partially drained the battery to trigger this or if it's just coincidental. Happened again today when with the family out of town and we were getting in the truck to head home - you'd have thought we were going to be stranded in the middle of no where listening to my wife. Anyway, after trying tapping on the relays under the hood with my knuckles and no results, I got it started after switching the IG1 No.1 and IG1 No.2 relays.
I'm not confident its one of them, but Ihave nothing else to go on. Any ideas?
Anyone know the location of the IG1 No.3 relay? Location of the 'intermittent relay' Mcewan mentioned previously?
Other than trial and error is there a way to test a relay with a multimeter or some other device?
Sorry, haven't been on Mud in a bit. Did you get your truck sorted @wesquire ?
According to the tech at my shop, the IG #3 was behind the passenger side cowl. ...which apparently necessitates the removal of the glove box and heater blower components?
I don't know what you can tell from the pictures but... after fighting this issue on my lx470... tap the relay to start ect... left my wife stranded a few times... I built a new relay and tapped a different power source (key on power) than what was supplying the factory relay... I believe the real problem is in the socket to the oem relay and not the relay... BUT this has worked or several years... Sorry I really don't remember the details... I built several and gave them to others having the problem... but that was a couple years ago... but it;s a simple 15amp relay just like you have controlling your off road lights, I actually had them because they controlled the tilt trim on one of my boats...
this is the first one i built in a parking garage where the wife was stuck ... built it out of bits in the bottom of my tool box...
I have been researching this topic over the last week. Finally had my 2006 towed to shop. They said a bad relay burned the junction box and it all needs to be replaced. Anyone have this occur?
1241987
1241988
1241991
1241992
How did you secure the relay in the box?
No worries. Went for a while without issue then two days ago I had the problem 3 separate times so it took it to the shop to diagnose - mine is the starter permthe shop so I'm waiting for the part to arrive Monday
