igniter vs coil
The igniter setup is an electronic ignition. Uses the points in the distributor as a switch only with very little current flowing through them so they will essentially last forever. Later model igniter setups use a distributor with a hall effect sensor and do away with the points entirely. The igniter also adjusts for dwell electronically. Basically the igniter setup makes it so you never have to worry about the points burning or ever setting dwell again. Had an igniter fail on a 77 FJ40 going up I70 years ago and I have been a little sour on them ever since. Hard to beat points and a coil from a reliability standpoint but electronic ignition is nice when it's working. IMO, just keep your stock ignition and carry a spare set of points and a matchbook in the glove box.
