Igniter Failure
How common is failure to igniter on 94 LC? I think I have narrowed a no spark issue to this component. Engine quit while idling out of driveway. The price of replacement part is ridiculous!
It isn't uncommon.
I had mine fail after some routine maintenance...it happens. From what I recall, there is no way to test an ignitor; you'll need to find a working one.
I picked up a used one from a Lexus for $50. I'll get another just to have as an extra.
thanks, yeah, I'm trying to track down another LC owner here in town and try his to see if it solves the issue. did you go junk yard to find the lexus part or through another channel?
Did you check the fusible links?
On the ignitor, you'll see a large number, "125", and then a denso part number below it.
I called around to a few Japanese specific recyclers in the Long Beach area and had them check the numbers for me.
The PN is the same for several years...I think CDan may have provided me the years, but can't remember.
Here is the PN description I was talking about above. Granted, this is for my 1991, I have to imagine this is simlar for a 1994.
IH8MUD.com - View Single Post - REALTIME: No spark after PM items
Check your EFI relay (may be called the main relay too). They are cheap (around 10-15 bucks) and very common to go. I found out the hard way after paying $300 to tow my rig for a $10 part. I bought a couple extra and keep them in the glove compartment. It went out again last week due to alternator issues, I believe. Popped it in and away I went.
Junk yards are filled with other toyotas, Some have your year due to cash for clunkers take your part or take a picture of it and match it to another model toyota. Mine matched that of a 4runner. good luck. Take some relays too while there .
Don't. Replace fusible link= burn down truck.
? why? if his links are blown then he knows to look for the reason why they are blown.
thx for the feedback. appreciate the EFI tip and the sourcing info. I will definitely check fusible links as well, not sure i understand the issue with burning down the truck?
The ignitor is probably dead. You might get the truck to run when its cold, but when its hot, it will sputter and shut down. To test it, you can put the hot ignitor in the freezer for a few minutes and it will run again. The ignitor will eventually draw too much current and blows the fusible link. BTW, the fusible link for the ignitor looked like a realy thin gauge of wire and not like a normal fusible link. Bypassing the link to get the truck home can cause serious problem. In my case, the entire engine wiring harness and part of the passenger cabin harness overheated and melted down. Cost a good grand just to have it replaced with a used one. A new harness is about $2k from the dealer.
Ok, after a month out of state, I have returned to repair my 94 LC. I went through all ignition diagnostics per repair manual and even tried a new igniter with no luck. Turns out, there is a 15 AMP EFI fuse that was fried. I had checked my ign fuses etc..but do not understand the relationship of EFI fuse as it would relate to a no spark issue. I had a mechanic locally run a diagnostic after because I now have a CEL on. There is a code "24". Truck running despite but says I need a new Mass Air Flow? Can anyone confirm? Do I need to dig deeper to determine what blew the EFI fuse? Can a bad AIr Flow meter fry this fuse? I did just complete a full Head Gasket repair about two weeks prior to this event. thanks.
