Idle RPM
Norfolk, VA
I could not find what the normal idle rpm on a LC is in the search section. My LC is idiling at 1000 RPM. Seems high, never really noticed until I started coming to this sight. Now I'm trying to listen to my LC to make sure its running correctly. What is the normal idle RPM?
x2, 650 RPM
I set mine a little higher though, around 750, due to the cold weather here in UT.
What does a higher than normal RPM indicate?
Keep in mind that the thing will idle fairly high with the AC on. Coincidentally the ESM lists the AC circuit as the first thing to check for high idle.
Magic... :flipoff2:
Kidding.
Turn the little (big) screw on top of the TB to adjust the idle. It might be a little stiff after 19 years....so make sure you have a good screwdriver....
Also, I don't believe the FSM says anything about it. But I did it over two months ago, and no problems yet.
I know about that trick, but: The computer usually compensates for the adjustment and eventually puts the idle right back where it "thinks" it should be, regardless of where you've adjusted the TB screw.
Good for you if that's not what happened in your case,
Curtis
