idle problems
Orlando, Fl
hey guys, i finally got this rig running but the only problem I have, so far, is how it idles....the truck revs itself and then almost stalls...and comes back up to an idle..and keeps repeating this...also when I accelerate slowly it jerks ALOT (but if I go quickly, it doesn't seem to do it at all)
Here's what I've replaced:
-spark plugs/wires
-dizzy cap/rotor
-points/condenser
-the only vacuum line I have going from the diaphram on the dizzy to the base of the carb
-gaskets on carb
-I've checked the timing and carb adjustments..but they may not be correct...
do any of ya'll have any ideas of what it could be?
****sand rider and I are heading out to ocala in 3 weeks with a whole bunch of jeepers to do some off roading..and I'm broke so I can' t get to the mechanic, although Its only been there once cause sandrider and i bust it out...and I would love to figure this out before we head off....thanks I appreciate it..
Stock carb?
Is your idle solenoid operating properly?
Do you have a switched 12V wire going to your carb?
Have you sprayed the base of the carb and the manifolds with carb and choke cleaner while it was "running"? any change in engine RPM's while doing this is a sign of a vacuum leak....
it is a stock carb and the solenoid is not connected...does this make a huge difference and where does it connect to? I haven't seen any wire that looks like it connects to it...not sure what you mean by the switched 12v wire
A switched 12V wire would be one that has 12v to it when the key is in the on position, and nothing when it is in the off position...
Look around close to the leads to the stock temp sender....there could be a female bullet-style connector there....grab a test light and see if it has power when the key is on....if so, then hook that up to your lead from the carb idle solenoid....or run a jumper wire to the + side of your battery for testing perpose, just to make the solenoid click....it should click open when it has power...then try and start your truck....it should idle a bit better...so long as the solenoid is working(clicking)...
The idle solenoid will not allow fuel into the idle circut unless it is energized open...so yes, it is important for proper operation of the idle circut.
you have PM.
:beer:
had the same problem, did a whole lot of screwing aroung with carb/dist, this on a 75, so some things are different. if you don't find a better answer, you can click on my username, then got to "all threads started by gladly" and some of them will be related to this. hth
thanks poser and gladly...do you think the idle solenoid being connected will fix my problem...or do you think it is something else? It acts as though at times its too lean..and then too rich...it never seems to balance itself out
Have you tried hooking up the wire?
Do that, and then adjust your idle speed and mixture.
AFTER you have done that, come back and report what has occured.
There is not an ounce of sense in continuing speculation on things until you have tried to effect change to a known bad issue. The situation that you have described falls right into the scenario of not having the idle solenoid attached or one that is not functioning properly. Resolve one issue at a time. You need to have things installed and wired correctly, before we can get into any further adjustments.
I definiatly hook up the wire and get back to you guys...I appreciate your help...I guess I just want to try and knock multiple things out at once when I'm chillin under the hood...thanks again
//newrider//
One other problem you've described is the vacuum advance.
If the truck is a stock 1970-1974, then it has a vacuum RETARD dissy. It also will NOT have a ported vacuum fitting on the carb base.
So what you have described is a vacuum retard distributor connected to a full time vacuum port on the base of the carb. That is a bad thing.
Remove and cap off the vacuum hose.
Adjust idle to around 600rpm.
Set the base timing to 10deg BTDC.
Readjust idle speed to 600.
Check that timing is still at 10deg.
Also, get the idle solenoid working per Poser's post.
Now you've got idle fuel and timing in the ballpark.
