Idle and A/C
Is it normal while in park with ac on hav3 the idle jump between 750-1100? Every time the idle rises or drops I can hear s omthing like a relay click under the dash. Thanks for the input.
I wish mine would do that! One of mine does it the other don't. The one that does it, runs great, the other struggles to keep up with the electrical charge:(
Yes, that's normal.
When the AC is on and ENGAGED, the RPM will jump to about 1200 RPM. When the evaporator reaches a pre-determined temp, the AC compressor disengages and the RPM will drop back to about 750.
You should see a consistent time frame between the events if you are parked with the truck idling and the AC on.
The click you are hearing is the AC relay.
Yes, that's normal.
This ... ^
Yes, that's normal.
So, this relay controls the RPMS?
The computer adjusts the idle to compensate for the load of the AC. The AC works best about 2000 RPM and higher, but you can't hold it at 2000 RPM in gear at a stop light. So they set it at 1200 RPM.
