i think its the carb
Brunei
i have this problem, when idling the engines fine but when i rev it.. the engine cuts off.. i checked the fuel lines all the way to the carb and pumps feeding fuel fine...
what is it?
First off, Welcome to the MUD. As for cutting out when reved, that could be any of a number of things. Check your float level and your jets. A little bit of dirt can sure reek havick.
Welcome to mud!
There are only 3 things an engine needs.
Fuel
Spark
Air
I would check the carb out, float level, visual inspection to see if the butterflys are opening properly that sort of stuff.
I would check the timing. and the points if you have them.
Make sure the air cleaner is clean and not obstructed.
Let us know a bit more about your engine, f, 2f, 350...
Good luck.
rezarf <><
i found out that a vacuum hose connecting to the distributor had a few holes in it. replaced it n now it runs fine... now my clutch doesnt work. found some fluid dripping from the master clutch pump. i called a few shops and they said theyre out of stock. does anyone know what other models has the same clutch pump?
