I need some help, engine stalls......
arizona
Website
www.roamingazexpeditions.com
Ok here my problem....
My '91 80 series was running OK but it had a rough idle after driving it a while so I decided to do a tune up-plugs, wires, cap & rotor. I noticed some vaccumm lines needed replaced so I started replacing them, one at a time so they should all be in the correct location. The EGR vaccum port was clogged so I replaced the EGR.
While I was doing all this work my friend that was trying to help me unscrewed and pulled all the wires off the mass air meter, so after about 3 weeks of ordering fiasco I finally got a rebuilt MAF and I installed it today tried starting and it revved way up, idled rough and stalled. I can start it and play with the throttle to keep it running but the slightest movment will cause it to rev really high then go back down , it will idle if I hold the throttle open but it makes a popping sound in the throttle body and misses. I did slightly tighten the trans and accellerator cable but very little.
I have checked all the plugs, gap is right
I put the old plug wires back on and cap is not damaged
I have checked over the vaccum lines several times, they all seem good
no leaks in air tube
The only thing I could find that could be bad is the vaccum modulater, would it cause it to run rough ?
also does the MAF need adjusted ?
I was told by the guy at checker it was the throttle position sensor but I dont thnk it is because everything worked before I started doing repairs and it hasn't been started since.
I dont get any trouble codes either.
I have searced the factory repair manual and it troubleshoots as a vaccum leak or MAF meter problem.
