- Joined
- Jul 26, 2008
- Threads
- 28
- Messages
- 354
I was trying to figure out if I should rebuild my front axle, so I tried to check if bearings have any play in them and I feel no movement in the hub. I went so far as removing the brake pads to make sure they don't scew my results (like in the rear axle) but now I am wondering if I need to remove drive flanges on hubs in order to feel play.
In My rear full float I could feel 2 mm play in the hubs after removing brake pads. On the front no such thing and I am wondering if those bearings are really so tight or something is fooling me.
Also Would you rebuild front axle if everything is tight, no noise and no leakage?
I am wondering if Axle would be fine to travel 1500 miles.
I mean if axle develops problems it should be seals to go bad first right ?
P.S. I am suspecting Toyota service repacked bearings when they were changing rotors and front calipers when I had brake problem during the winter.
