I need fender flares
Golden, CO
My 40 has cut rear wheel wells to make room for the 35s I don't have but I want to get some flares on there anyhow. What are my options? I've seen the Bushwackers but they seem a bit pricey. Has anyone used the plastic fenders that you cut to length? What have you guys used? Thanks. D :cheers:
If you have a local 4x4 shop, they have probably swapped a set of aftermarket flares onto a &%ep TJ, and have a set of stock flares lying around. Alot of people are running stock TJ flares on their 40's and is a good option IMHO. The 4x4 shop is just an idea to get them a little cheaper than form the stealership. Also check with a local 4x4/&%ep club, there is usually someone there trying to ditch some stock TJ flares. Hope this helps.
mine had some rubber stripping on (i think they are meant to be used as flares) that worked well in keeping water/mud down... i took em off when i trimmed my wheel wells and haven't put em back on. to tell you the truth they looked haggard, but its a cheap option
Chuglife:
Thanks for your help. But why do you put the size of you "manhood" in your sig line "4 inches" :D
