I bought my first 80 a little over a year ago and have been slowly fixing all the little issues and baselining. After owning it for about a month it started to idle a bit rough and seemed to be down on power. The O2 sensors looked original so I started by replacing those with 1995 Denso sensors. Bank one had some corrosion in the connector so I thought for sure that was the issue. At this point the issue became worse. The engine had no power, misfired and would barely run with the O2 sensors plugged in, but runs well with them unplugged. If I drove it long enough with the O2’s connected, it would throw a code 26 rich mixture. I tried reinstalling the old O2 sensors and replacing with a 2nd new set but no difference. I replaced most of the parts relating to the fuel mixture and tested the rest per the FSM but no luck. The O2 sensor voltages were .6 on bank 1 and .8 on bank so slightly rich and very rich. Long story short, I decided to send out my injectors for testing/cleaning. 4 of them are leaking and need to be replaced. I have ordered a set of Bosche “upgrade” injectors from Cruiserparts.com. I will report back with the results once a receive them. I wanted to write this thread as I’ve seen a few similar threads on this issue with 93-94 cruisers but no definitive solutions. Here’s a list of things I did to get to this point.
-1995 Denso O2 sensors, deleted PAIR and relocated.
-checked sensor signals at the ECM per Fsm
-replaced ECM
-ECT sensor Replaced
-EGR deleted
-all Vacuum hoses replaced, VSV’s tested
-VAF tested per fsm
-replaced VAF with eBay junk (don’t do it! Wouldn’t even run). Reinstalled old unit.
-spark plugs
-fuel pressure test
-regulator replaced
- compression/leak-down
-valve adjustment
-replaced ECM
-EGR deleted
-VAF tested per fsm
-spark plugs
-fuel pressure test
-regulator replaced
-valve adjustment
