I got a new CD player...
Hello,
I have a '97 LX450 with an aftermarket CD player that recently quit working. I wanted to go with the stock look and I didnt want to pay 14 gazillion dollars for a stock LX changer (and I also wanted an in-dash player). After searching multiple junkyards, I finally found one that would fit. The unit came out of a '00 Camry. It looks very good installed, the harness matches up, and works great; however, it doesn't dim and the controls don't illuminate when I turn my headlights to the "on" position. Does anyone know how I can wire this up to make it work properly?
If you have the wiring diagram for both, you should be able to find out which wire is the lighting controll.. Odds are it is on a different pin for the Camry than your unit, connect that correctly and your golden. It is possible that whoever did the original install of the after market deck messed something up as well, or changed the original wiring to suit the after market decks needs... So unfortunately there is no easy answer when dealing with a "factory" deck, this is why most after market decks come with easily identified wires... Good Luck
