- Joined
- Nov 13, 2004
- Threads
- 6
- Messages
- 374
Problem: Front end vibration.
Description: A Grrrrrrrrr noise/vibration that can be heard from the front and felt through the steering wheel.
Background:
'97 LX450, 147k miles.
Repacked front and rear axles last year.
Finished HG PM this summer. Thought I messed up when the engine started to smoke on the initial start. Turns out I reassembled the AC idler pulley wrong.
Problem, redux: Over the last several weeks, I noted a front end vibration. A "grrrrrrrrrrr" sound that was proportional to the accelerator, but independent of speed and park and neutral.
Deduction: Prob something in the driveline. After reading the FAQ, I suspected u-jts. I greased it. Didn't seem to need much. Still the "grrrrrr". I guess time to replace the u-jts!
Mistake:
(1) Oil stains: I also started noticing oil stains on the driveway. It was under the engine. With the recent HG PM, I had an unsettling feeling. I unbolted the steering stabilizer, unbolted the front dust shield and looked around. Looks like the ol' oil pump gasket.
(2) In addition, I had some leftover gear oil in the garage and since we are in the midst of a move, I decided to replace the diff oil. The old oil looked very clean and the drain plug had very little debris on it.
After everything was buttoned up, I took the truck for an errand.
Lo and behold, no more vibration/"grrrrrrrr"!!!
So, it was either:
(1) gear oil. (Didn't look dirty or feel low, but I didn't measure amount).
(2) steering stabilizer.
(3) front dust shield.
Anyways, I got lucky and I hope this helps others.
Background:
Mistake:
So, it was either:
