HZJ79R Workshop manuals
Hi All,
My apologies if this has been answerd before....
I'm looking for a workshop manual for a HZJ79R crew cab. I've looked at the site noted in the sticky, but can't find a manual specifically for the HZJ79.
Could anyone point me in the right direction, or advise if (for example) a 75 manual is applicable?
Many thanks
Probably not much out there for free. You can get an engine manual here Offroad 80's • Factory Manual Downloads.
Be aware there is a difference in the 1HZ timing pulleys on pre 98 or thereabouts .The later ones have 2 extra teeth on the belt.
For a body/chassis manual a 75 series will suffice and its not largely different to a 60 series in many regards.
Crew cabs are not a factory option (yet) so yours must be a conversion?
Hi Rosco,
Many thanks for your help.
It's what I thought we called a crew cab! In NZ, a 4/5 person cab in known as a double cab. It's a 2003 model.
I've downloaded a copy of the 1HZ WSM from forums.bauchan.org website and noted the difference in timing belt.
Cheers,
Paul
