HZJ77 Suspension
Does anyone know where I can get a heavy duty suspension lift kit for the 77 series? Apparently OME does not make one for this vehicle.
It helps if you mention your locality so those in the know can direct you to the nearest likely dealer.
Is it leaf springs all round?
Lovells and Ironman both list a kit for a 77 series. I think Dobinsons would also have one if you asked.
Their heavy duty kits are listed as for mine use. Make sure they are not going to be too harsh
I have a standard duty Dobinsons kit with steel bullbar on my 73 series and I find it ample for my needs
The front springs are the same as the 70/74 series,the rearsl can't find,so l got the ZEAL kit from japaninstalled it couple of months ago,ARB bullbar,roofrack and ARB rooftoptend and awning,haven't testdrive it yet,waiting for the snow to melt,still lots of salt on the road here.l can get them from Japan or MOT od Dave stedman on the list here probably can get them.
Simon
Maybe not your style but when I beefed the springs on my JDM BJ70 I picked up the thick Rancho add-a-leafs for a Jeep YJ to replace the 2 shortest factory leafs on all 4 corners and had KalTire's spring shop make me a set of longer add-a-leafs to use in the middle of the pack. 18 months and only 300 bucks later, no sagging and rides good. I've gone the $1200 Belton route in the past. So far the add-a-leafs have made me every bit as happy at 1/4 the cost.
Others will disagree.
:beer:
The previous owner of mine installed OME 70 springs on the front and then used most of the OME 70 rear springs for the rear except the main spring. It has been on the truck for almost two years and it has been fine. Lots of shops dealing with ARB in the Lower Mainland should be able to help you with this.
