HZJ75 part number help please
Australia
Can someone please help me with some part numbers?
For a 1990 HZJ75
JT731PJ7508502368
Window winder mechanism for manual operated window in a RH door with a vent window. The one I've circled in red. Not the other one with the scissor arm mechanism.
But when I click the number, it gives me four part numbers, and if I click on the other one it gives me the same four numbers.
Can anyone tell me how to understand it?
Check ToyoDIY
69801-60020W(*PW)1
69801-60030W(*PW & *VW)1
69810-600901
69810-90K01W(*VW)1
[td]69801[/td][td]REGULATOR SUB-ASSY, FRONT DOOR WINDOW, RH[/td]
[td]
$100.71​
[/td]​
[td]
$75.07​
[/td]​
[td]
$100.71​
[/td]​
[td]
$75.0​
[/td]​
Thankyou!
Next question - what about the rubber grommet for the odometer reset knob on the instrument panel?
3d print a replacement? I'm not sure if TPU filament is flexible enough.
Sump for a 1996 HZJ75.
Mine has an oil level switch on the left side, but this picture doesn't show it.
Which part number do I want, to get one with the hole for the oil level switch?
I think you have the correct PN for sump with sensor 12101-17100 Here's a photo from Partsouq showing the sensor hole.
Thanks mate, what would the slightly cheaper 12101-17110 part number be?
If I use an older serial number of the era that had no oil level sensor, it says the sump is 12101-17040. So it seems odd that there's two part numbers for the era with the level sensor.
I'm not sure that 12101-17110 is actually available anymore, but that sump should be the same as 12101-17100 if you can get it. Is the 12101-17100 not available to you locally in Australia? The no oil level sump 12101-17040 is definitely no longer available new.
For people that don't have an oil level sensor there is a Daihatsu plug that fits/seals the sensor hole perfectly PN 12129-56010-000 and the screws to bolt it in place are toyota 93385-16014
Great information, thankyou.
I haven't actually checked local availability on this one yet.
Importers have become a rather attractive option when there's ability to plan ahead, due to severe cases of "dealer tax".
Price differences vary a lot, but some things are insanely more expensive at the dealerships.
Dealerships were my go-to for many years but I'm sick of paying too much.
You probably know about these guys... but they may have a good used one for you.
Thanks, yes they come up sometimes when doing internet searches.
Looks like there's unfortunately not a Daihatsu plug anymore.
