Hzj 70
edwajon
10 Year 15 Year
Raglan.NZ
Hi there everybody,
got a couple of HZJ's in New Zealand , just wonder if any body else has had corrosion problems with the windscreen panel & how they fixed it ???:cheers:
Hi there everybody,
I dont think there is any magic cure except to try out your welding skills patching them up.
The best policy for them is prevention by fixing rust as soon as it starts and allowing the vehicle to dry out on the inside by letting the windows down on fine days.
Hi there everybody,
This is a 'standard' issue in the 7 series. Most of them have this problem. I tried to avoid this by removing every bolt I could find on that frame and squirt lots of rust-inhibitor (ML) in the inners. At that time the rig was fairly new and it seems as if it helped.
But be aware of some other areas as well:
1. In between the frontdoor post and rear wheelwells
2. In between reardoor and rear wheelwells
3. The wheelwell seams where the inner and outer panels meet
4. Lower seams of the doors (where inner and outer panel meet
Especially the areas rearward of the frontdoor posts are at risk, despite treating them and drilling holes in the bottom (I found standing water in there!!) they now are being repaired because of rust.
Hi there everybody,
Do you mean a 70 with the windscreen fixed permanently or a 73/74/75 with the separate frame that unbolts?
HZJ window frame
Guys ,
thanks for the advise I have replaced one frame already on the HZJ 73 . and now you can just start to see it coming up on the 96 HZJ 70 factory canvas top , I thought bugger it, and bought a new frame ($950 nz) and posted this incase any of you guys have come up with any cunning plans
:beer:
