Hypoid Limited Slip
Can I use CRC Sta lube API GL-5 SAE 80W-90 hypoid limited slip gear oil in the Diffs and transfercase? I have a 96 cruiser with factory lockers.
It may have an addditive (friction modifier) for LSD's in it that may or may not be good.
The LS additive package should not matter in open diffs. It is only when you have a LS diff and don't put the additive package in or use a fluid with it, you get chatter. Why not use a better oil? Any major oil manufacture oil is likely to be from a better basestock.
