Over the last few weeks I've been collecting and making parts to install hydroboost in my 78 FJ40. I have 80 series axles so the 80 master cylinder seems like a logical start. I read of another member using an Astro Van booster so I purchased one of those. The rest is custom.
This is the shot of all the parts laid out and the unused Astro Van parts beside it.
Starting at the left:
What I believe is Minitruck plate and aluminum spacer.
My custom plate under the input rod with tab to prevent rotation of the booster
retaining ring and square nut are astro van parts.
Metric fasteners
Astro Booster itself with Minitruck clevis on shaft.
-6AN fittings installed in booster, 3 places
I cut off and then threaded the shaft M10x1.25
Custom length output shaft (Grade 8 bolt, 3/8x6") about 108mm long. Plastic washer already installed.
Astro spring and keeper.
M10x1.5 bolts to secure adapter plate to booster because that is what I had on hand
Centering ring, custom made out of aluminum, will post image of dwg later.
Adapter plate, aluminum 5/8 thick, 60 deg rotation to clear my intake tube. Can post drawing later
80 Series master cylinder with bolts and washers I had on hand.
Paint is currently drying, More to follow.
Metric fasteners
