Hydraulic Pump
Scotland
Just got hold of a hydraulic log splitter that is designed to be run by tractor hydraulics. Don't really have any other need for a tractor so looking into alternatives to power it.
First thought was a power steering pump belt driven off the engine but don't know if it'll have the required pressure/flow rate?
My 1-HDT doesn't have air con so might be able to fit something where the air con pump would go?
Alternatively is there any dedicated pumps available that would do the same job?
Any thoughts/ideas welcome! :)
Jamie
You could get a 12 v DC motor, and mount that. Connect that to a hydraulic pump (either directly, or by a belt). The pump can then connect to your log splitter.
That two stage pump will require quite a hefty motor to run it, the reason I asked if you had any compressed air is because I can supply an hyd pump that can produce 2000psi at 100 psi air pressure or 4000psi at 100psi air pressure it contains its own oil tank too, just connect an airline to it and it will produce either 2000psi of hyd pressure or 4000psi depending on what pump you want, I also have the hand valve that makes the pressure go forward and back.
Have a look at the link below
GX Series
