hy steer question
What is stopping us from swapping the knuckles from ps to ds and vice versa and flipping them upside down. allowing the use of mini truck hy steer arms. I am at work right now and just got the idea so i can't look at my truck.
thanks peyton
The mini-truck has a major design defect with the low tie rod directly in front of the axle that the hy-steer solves. Toyota engineers fixed this with the 80, by relocating the steering rod to behind the axle where it's relatively safe for the vast majority of us. Plus I'm not even sure there's room for a hy-steer system with the coil springs and shocks in the way.
On the other hand, if you go too high on the 80 in terms of lift, the steering will have to be lifted somehow to keep the drag link from going too steep. I'm not sure how this is compensated for the upper end lifts, like 6+", but I'm guessing they do some kind of steering mods.
This is the hy-steer set up on my old mini-truck. It worked great for it's purpose. But even with a good 4 to 5" of lift, the tie rods would hit the frame at full flex...another disadvantage of hy-steer, depending on where the rods run relative to the curverature of the frame.
By the way...this truck had 80 series tie rod ends for added strength and an 80 series hi-pinion front diff to compensate for the lift and raise the front driveshaft angle and even an 80 series pitman arm, cut down to fit. Common mini-truck upgrades, especially for SAS trucks.
The lower picture shows the mini-truck axle with it's front tie rod, clearly being a potential problem, thus why the need for hy-steer.
i've been working on a new design for fj80 high steer for a while. it's a new cast knuckle with a beefy arm that will bolt right up and be stronger than any toyota knuckles and arms out there. i'm in the process of having plates made for the castings. i'll keep you posted on my progress. these axles are a huge upgrade from the mini axles, and without the need to upgrade the birfields they should be around the same cost as a fully built mini axle. only stronger and wider, with bigger brakes.:cool:
