Here is the deal,
1975 FJ40
I am doing a PS conversion as part of a SOA. This also includes Hy Steer and a mini truck knuckle swap. My kit was ordered with FJ80 TRE's.
Because of some suspension mods I did the PS gear box was moved to passenger about 1 1/2". As a result the drag link (connects the pitman to the passenger steering arm?) is to long.
The pitman arm I found is from a Grand Wagoneer. Eyeballing things it looks like this will make the Drag link almost horizontial.
The original plan was to modify a pitman arm to mate with the 80 TRE. Since I need to shorten the drag link any way I'm thinking I might as well modify it to take the Wagoneer TRE (or a hiem joint and drill the pitman arm to fit that).
The options are;
1)Stick with the original plan, send the draglink to All Pro to get it shortened and pay to get the pitman reamed to fit the 80 TRE.
2)Cut and sleeve the draglink, weld in a bung for the Wagoneer TRE.
3)Cut and sleeve the draglink, weld in a bung for a hiem joint. Drill the pitman to fit the hiem end.
What does the collective wisdom of Mud think?
1975 FJ40
The options are;
