HUD Alignment
Curious if anyone else has noticed any issues with the alignment on the HUD, during our test drive I thought ours looked a bit fuzzy but thought maybe it was my eyes. Once we got home I was playing with the settings in the driveway and could see more clearly a misalignment. Going to have dealer check it out in the next week or so but wanted to see if anyone else has seen this issue on theirs. If you look at “MPH” you can see it’s double posted and shifted slightly.
Did you change the position of the HUD via the settings? If I recall correctly, mine became less blurry when I moved the position up or down (not sure which).
Tried changing up/down and played with rotation. I discovered earlier today that if I lean way to the right that the text becomes perfectly clear right at the edge of the display area on the windshield. But sitting centered on the wheel it is not clear.
