hub options
I would not engineer a weak point into my driveline, ever.
If you are breaking lockouts, you are over-taxing your running gear and need to figure something else out, period
:beer:
I dont know, but just this yr breaking (about 6 trips)
inner shaft, birfields one stock two 27spline longs, two ring and pinions 4.10 5.29, sheared lockout studs, sheared pins and broke parts of a brand new lock right, but no busted lockouts. time and labor to fix all this.
some cheap hub fuse if it helps from popping all these $$$$ wise it makes more sense then any other mod. no experience with these just yet.
granted this was a mini axle, so ring pinion is an issue.
Well shortly after posting this thread I found out the guy also has the Aisin hubs for the birfs. So I'm covered there. But this thread has covered some good points. Later all
Chuck
i've exploded the casing of a warn lockout..
and texican the reason i push the aisins is because their stronger than the cheese strengthed warns/
