Hub bore size?
UAE
Does anyone know the hub bore size for a late-model 70 series? In this case it's a 2010 GRJ71, but I'm guessing it will be the same for the previous model FZJ71. I suspect it's 110mm but I don't have calipers to take an accurate measurement. I'm looking for new wheels. I know the bolt pattern I need (5 x 150mm) but I don't want to make the schoolboy error of buying wheels with a centre hole that's too small for the cruiser's hubs!
In case it's of use to anyone, I've taken some measurements and I'm now pretty sure the hub bore diameter is indeed 110mm. I used a tape measure to calculate the circumference and worked backwards from there. Not scientific but hopefully close enough.
110mm is correct.
