HP 8" strength
Mine has had 37"s on it for ~10yrs, the thirds have never been out of the truck, all axles and birfs are stock. Tons of wheeling and other than one instance with knuckle studs, zero axle issues. That said, mostly desert wheeling, rock, sand, little slop, so your conditions likely differ. Excessive wheel spin, momentum wheeling, wheel hop, etc, are the ways to destroy axle stuff, we try to avoid that and mostly isn't needed in our conditions.
Open diffs are harder on axles than anything I have ever seen.
Do you plan with Elockers or like an air locker, that is a subject to be addressed.
I've read if you go past a 37" tire you might consider going with a air locker type carrier.
Snapped axles in a Elocker I have heard is a PITA. This is what Landtank addresses with his axle fix etc...
I've been running 40's for 4 years now. I usually run the harder trails. Haven't broken a ring and pinion yet. I've broke tons of birfields but since I upgraded to longfields I haven't broken one since. When I was on 37's though I broke my front diff. That is the only time I broke the ring and pinion. I was climbing this snowy hill when I hit a bump which send my front end off the ground under power. When the wheels came back down they caught traction and busted the ring and pinion. I've been waiting for it to break with the 40's but it's been holding strong.
