Howdy
Chugiak, Alaska
Fj55 rear replacements?
Just curious, what is a good replacement spring for rear FJ55's. Mine are sagging pretty bad and I either have to tear down the saggy pack and add some leaves or put in a different set. FJ 55's are hard to come by up here. Are there any other springs that are about the same legnth?
I don't know much about 60 springs, are they wider than 55's? About the same legnth?
I'd love Alcans, but I don't have the funding to buy new lift springs. It's already SOA so 4-5" lift springs would be HUGE.
Where are you located? I thought I knew all of the SOA Pigs up here.
If you are up to some minor fab work, a set of the long chevy springs (63 inches) in 3/4 variant works really well under a '55.
You will not find any other springs that are a close bolt in and are not worn as badly as you springs.
Adding leaves works well and is easy.
An approach that Ihave used on a handful of SOA rigsa is to add coils pon top of the axles. Three important considerations. Picking the right coil for the rig. Mounting it cleanly and securely. Setting the whole arrangement up so that it doesn't limit or hinder articulation.
Actually pretty easy. Works very very well.
Mark...
Correction, not a pig
Just a Fj40 with rear FJ55 springs in the back. Yes you sort of know the rig, I'm Toy4Fun on the Alaska4x4network (that name was already taken on this board). I bought a fuse box from you a few months back and some hard top brackets last year. I don't think I can fit 63" chevys on the 40. I heard something about 52" Chevy tahoe springs, but don't know anyone who runs them.
Okay, now I know who I'm talkin' to. ;)
Yeah, you won't fit the long Chevys under a '40
I've got the coils I mentioned under a '40 with '55 rears. Works GREAT!
Mark...
So did you strip down the spring pack and us it for axle location or you used coils along with the full spring pack? What is under your tan 40 with the boggers?
I've got the full leaf spring treatment. FJ55 rear springs, front and rear under the '40, with the perches redrilled for an extra incha and a half or so. It is a very soft and very low SOA. Flexs fantastic. But... at normal trail speeds over any sort of rough terrain, with any sort of load, I was bottoming the suspension out. Especially the front. And when loaded heavy for a longer trip on the trail, the rear was sitting lower than I liked. So I added coils at both ends. Just to carry weight and put the ride height where I wanted it. Origianlly I did it just for when I was loaded up for a longer run. It works so well and rides so nice I leave them in most of the time (I can have them out in 10-15 minutes and back in in not much more).
I uses Geo Tracker springs under the front and Ford Aerostar 4x4 LWB rears under the rear. The Aerostar springs are particularly great for this. The are tall, soft, progressive and compress to a pretty short height. 10 inches stacked and IIRC about 20-22 competely unloaded.
When all is said and done, the rig rides smooth but firm, flexes with no restrictions and carries heavy trail loads nicely. Oh yeah, with the 39.5 boggers I'm still road legal for frame height. ;)
I am very pleased with this setup. A couple of the other guys locally are planning on doing the same under their rigs after watching mine on the trails the last couple of seasons. ;)
Mark...
There's pictures of the rig floating around. I had some shots of the shackles showing a bit of the leaf spring and the shackle angle posted in a thread here. I probably had a picture showing the 8 can gas rack on the back. But I have not taken any of the coil setup.
It's pure low tech junkyard engineering. I like to think that it is clean and thought out. It is defintiely field tested and proven. But it is not rocket science.
There has ben no write up of it or major discussion of it on the net. It's been more of a real world, try it and change it 'til it worked right type of thing.
We've also done a similar approach under a '60 to counteract the typical "sagging springs after an SOA" that the '60s expereince. That setup was not aimed at max articulation though.
Mark...
